TwinTurbo.NET: Nissan 300ZX forum - Re: Check for lean cond. via O2 diagnostic on ecu n check plugs
Lowlife1998
on April 14, 2018 at 3:26 PM
Check for lean cond. via O2 diagnostic on ecu n check plugs (n/m)
posted by Zbruh92
on April 14, 2018 at 02:49 PM
Plugs seem fine there dry and clean
300zx tt dies after high rev
Lowlife1998
11:26:26 04/14/18
Depending on how you rputed the catchcan you may be...
kickerzx
11:44:58 04/14/18
Re: Depending on how you rputed the catchcan you may be...
Lowlife1998
12:33:15 04/14/18
Zbruh92
14:49:47 04/14/18
Re: Check for lean cond. via O2 diagnostic on ecu n check plugs -
Lowlife1998
15:26:24 04/14/18
FPR or perhaps clogged fuel filter? I’d test fuel pressure (n/m)
Zbruh92
18:17:06 04/14/18
At vacuum the pcv valves normaly put a vakuum
kickerzx
14:56:07 04/14/18
Re: At vacuum the pcv valves normaly put a vakuum
Lowlife1998
15:27:35 04/14/18
Lowlife1998
19:37:21 04/14/18
In that case look for pinched orings on your newly installed
kickerzx
02:02:49 04/15/18
Re: In that case look for pinched orings on your newly installed
Lowlife1998
10:12:48 04/15/18
